Slack 63.5° head angle, 165mm travel and a long 1290mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
E-Spartan Lite 2026
Light-assist alloy e-enduro on Bosch's Performance Line SX, 400Wh and around 21.5kg
The Devinci E-Spartan 2025 is the GX-trim aluminium full-power enduro eMTB from the Canadian brand — discontinued as of 2026 in favour of the newer Spartan platform. Built around Devinci's Split Pivot suspension layout, it offers 180 mm front and 170 mm rear travel, a properly slack 64.0° head angle, and a claimed 24.6 kg ride weight. UK base price was £6,799 for the GX trim. Although the 2025 model is no longer in production, it remains widely available as new-old-stock and on the used market at discounted prices. The community places it firmly in the long-travel-29er enduro conversation: @jbrown15 describes it as "a 29er long-travel eMTB with 700 Wh or larger battery using a Shimano motor rather than Bosch" — alongside the Norco Range VLT as primary peer.
Drive system and range. The 2025 E-Spartan typically ran the Shimano EP801 motor (85 Nm, 600 W peak) paired with a 720 Wh BMZ pack — the same drivetrain layout as the 2024 model, with detailed gold-fact motor figures not explicitly listed in this spec. Shimano EP801 is the refined evolution of the long-running EP8, with the same 85 Nm peak torque but better low-cadence response, quieter operation and full Bluetooth/Di2 integration. The 720 Wh battery is removable for off-bike charging and gives roughly 1,000-1,300 m of climbing per charge in trail conditions. E-Tube Project app integration provides ride mode customisation and over-the-air firmware updates.
Geometry and handling. The 64.0° head angle is squarely enduro-spec and matches benchmark rivals like the Trek Slash+ (63.7°) and Norco Range VLT (63.5°). Reach progresses S 440 mm, M 460 mm, L 485 mm, XL 505 mm — generous modern sizing with a notable 25 mm jump from M to L. Chainstay length is fixed at 455 mm across all sizes, prioritising stability over agility. Wheelbase opens 1,236-1,314 mm — properly long-and-slack figures that confirm gravity intent. 29in wheels front and rear, no mullet option.
Build and value. The GX trim at £6,799 represents Devinci's sensible value spec. Expect Fox 38 Performance Float forks, Fox Float X Performance shocks, Shimano XT four-piston brakes and SRAM GX Eagle Transmission. As a discontinued model, current pricing should typically be 15-30% below the original RRP at dealers clearing 2025 stock. The aluminium frame keeps overall cost down compared to the carbon variants Devinci offers elsewhere in the Spartan lineup. Devinci's Canadian manufacturing pedigree is genuine — they remain one of the few brands building frames domestically in North America.
Caveats and known gripes. The most significant issue is that the 2025 model is discontinued — replacement parts (frame-specific bearings, particular linkage hardware) will become harder to source over time. Devinci's UK and continental European dealer footprint is much thinner than the brand's Canadian/US presence — service paths outside North America require careful planning. The fixed 455 mm chainstay across all sizes compromises weight distribution for shorter riders, who end up sitting too far rearward. At 24.6 kg the bike is mid-pack rather than light. The Shimano EP801 motor's 85 Nm is now overshadowed in headline-figure terms by Bosch CX Gen 5 (120 Nm) and DJI Avinox M2S (150 Nm), although EP801 reliability and quiet operation remain genuine selling points. Forum community footprint on this specific bike is thin compared to mainstream-brand rivals.
Verdict. The 2025 E-Spartan is for the rider who can find discounted new-old-stock or used examples and wants Canadian-made enduro-spec geometry, proven Shimano EP801 power and a removable 720 Wh battery at sub-RRP money. It suits North American buyers within reach of Devinci dealer support. It is not for UK or European buyers without dealer access, riders chasing the latest 100+ Nm motors, smaller riders who want size-specific rear triangles, or anyone needing long-term part availability assurance. Production status: discontinued. Devinci has moved on to the 2026 Spartan platform with revised geometry and updated motor options.
Short 455mm rear and a lighter build — easy to pop, manual and throw around.
Balanced front-to-rear in L (FC:RC 1.84) — weight sits evenly between the wheels.
the motor and a steep 77.1° seat angle keep the weight planted over the front — a proper winch.
Easy to throw around; happiest when you're active on the bike.
| M | L | XL | |
| Reach | 460 mm | 480 mm | 500 mm |
| Stack | 634 mm | 643 mm | 652 mm |
| Chainstay | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 63.5° | 63.5° | 63.5° |
| Seattube Angle (eff) | 77.2° | 77.1° | 77° |
| Wheelbase | 1260 mm | 1290 mm | 1314 mm |
| Front Centre | 805 mm | 835 mm | 859 mm |
| FC:RC | 1.77 | 1.84 | 1.89 |
Trims · 2
Eagle 90 12s $6,099 | GX AXS 12s $7,499 | |
| Motor | Bosch Performance Line SX | — |
| Battery | Bosch PowerTube 800 · 400 Wh | — |
| Travel F/R | 170/165 mm · all trims | |
| Frame | Aluminium (6061-T6) · all trims | |
| Fork | RockShox Zeb Select DB, 170mm, 29" | RockShox Zeb Ultimate DB, 170mm, 29" |
| Shock | RockShox Vivid Ultimate | 205X65T · all trims | |
| Headset | FSA Orbit 1.5 Zero Stack · all trims | |
| Stem | RaceFace Turbine | B:35mm | L:40mm | 0° · all trims | |
| Handlebar | RaceFace ERA 35 | B:35mm | R:40mm | W:800mm · all trims | |
| Grips | Devinci lock-on · all trims | |
| Saddle | SDG BELAIR Max eMTB · all trims | |
| Seatpost | SDG Tellis 31.6mm · all trims | |
| Brakes | SRAM Maven Bronze, 220mm front / 200mm rear | SRAM Maven Silver, 200mm rotors |
| Rear derailleur | SRAM GX Eagle AXS | T-Type | 12s · all trims | |
| Crank | SRAM GX Bosch | 155mm · all trims | |
| Shifters | SRAM AXS POD | 12s · all trims | |
| Cassette | SRAM XS1275 | T-TYPE | 12s | 10-52T · all trims | |
| Chain | SRAM GX | T-Type | 12s · all trims | |
| Drivetrain | SRAM Eagle 90 12-speed, 34T, 10-52T | SRAM GX Eagle AXS 12-speed, 34T, 10-52T |
| Wheels | RaceFace ARC30 on RaceFace Vault hubs (front 15x110mm, rear Boost 148x12 XD), Sapim Stainless 14G spokes; 29in front / 27.5in rear | RaceFace ARC30 (29in front / 27.5in rear, 30mm inner) |
| Tyres | Maxxis Assegai 29x2.5 (front); Maxxis Minion DHR II 27.5x2.5 (rear) · all trims | |
| Weight | 21.65 kg | 21.45 kg |
| Price | $6,099 | $7,499 |
Rides similarly
Spot a mistake?
